Andrew Jackson
New member
- Nevada
Hello, Trying to find the answer in the NEC and having issues. Been an electrical contractor for 20+ years and from time to time I run into "the new rule" (albeit old) being enforced by our local municipalities. We do small design build commercial projects as well as residential custom homes and when I design the loads we try to stay at 80% or under the max amperage rating for circuits electrical panels or other.
On a sfr remodel we are doing an inspector is calling us on exceeding the 80% capacity of an existing 100 amp sub-panel with three existing ac units and one new water feature pump. Total load calculation on the sub-panel comes in at 86 amps. So I am trying to find the answer in the NEC to show this inspector he is misunderstanding or that I am wrong. And if it is the case that I am mistaken our industry needs to just change all the rated breakers, panels, etc to what is real. WHY would we have a 20 amp rated breaker that can only have 16 amps on it or for that matter a 3,000 amp 480 volt panel is only good for 2,400 amps??? And that would open a can of worms when selling a 3,000 amp service (which we are in the bidding process of) and is only good for 2,400 amps.....law suit ensues..........
Thanks for any assistance, Andy
