You are on hard core dude. I am not sure this is ever an issue as it does not cost the customer anything so it does not hurt and its there if you change your mind
It is just not something that happens around here..the only time any utility is extended to a home is when the property owner requests it.
They will install the back bone facilities on public property or within a utility easement that was granted when the area was subdivided for development. That easement does not normally extend to the building, it just runs on the edge of the property. Without a request for service, a utility has no business running anything on private property outside of a granted easement.
The only utilities that are required, by our locally adopted codes, to be extended to a dwelling unit are water and sewer. Anything else is optional.
I agree-- there are many people who use cell service and will not have a landline and even with the jack operational it does not insure the home owner will use a phone to plug into it.
Even with an actual phone connection, in many areas the phone companies are switching over to IP based phone service which is not near as reliable of a hardwired connection to a central office. With a hardwired connection to the central office there are large battery banks and a generator to provide phone service in the event of an extended power outage. With IP based phone service, there are a number of pieces of equipment that require battery back up, but the back-up is a few hours, as compared to many days for a hard wired connection to the central office.
Most cell phone systems are more reliable than an IP based phone line.
Well over 70% of 911 calls come in via cell phones now and that number is going up each year.
Well we better get used to it as the nec seems to clearly overstep its bounds and has become somewhat of a design manual. It states it is not intended to be a design manual but...it's intent does not mean it will not be :weeping:
It is just like all of the homeland security nonsense...as long as we keep looking the other way and ignoring the rights that our government is trampling on, it will continue to happen.
