Controls Guy
- Central PA
I am writing to request a common sense test on specifying a new ASCO 4000 automatic transfer switch for a waste treatment plant.
This is a an underground replacement service with new 800A 480 3 phase disconnect and tentatively an ASCO model 4000 service entrance rated transfer switch.
1) Does anybody have good/bad experiences with the ASCO 4000?
2) Should I select a switched neutral or a solid neutral connection in specifying the model? Common sense indicates a switched neutral would be more advantageous, in case there is issues with the utility.
Thanks
Thanks
