milemaker13
- Suburbs of Chicago
We will be installing a new press line in the near future. The press itself requires a 200 amp 480v service. There will also be ancillary equipment suck as a decoiler, straightner, feeder, stacker, ect.
Future planes also call for a coil sheeting line.
Our main service panel in this building has an 800 amp breaker that was installed for this project. My question is how to best handle the 800 amps from the main panel to the new press area.
I was asked to provide the 200 amp drop for the press. I figure I have 2 options: Buy more breakers for the service panel and run everything individually, or bring the 800 amps to the area and use a tap box to power two 400 amp breaker panels.
I am leaning towards the tap box and using either 400 amp breaker panels, or seperate fused disconnects for each machine.
The main panel is about 140' from the press area. I'd be looking at maybe 170' of pipe to run a tap box situation (depending of course where thay decide to put this electrical equipment.
For 800 amps I would plan to use two networks of 500mcm cable each in 3" EMT.
Thoughts?
Thoughts?
