I am quoting a new 800 amp 3 phase 277/480v service to a building.There are 4 seperate wharehouses inside this building.I need to feed each space with 200 amp panel.Then use step down transformers.My question is what is the best way to handle the main service part? they want each space sub-metered.Do I use a troughw/ inline meters with disconnects?CT cabinet then use house / read meters.Iknow they dont make a meter stack that will handle 800 amps.Also if i just use a trough how do i make my tap to the parallel feeders.Just make sure there balanced?
