8ft fluorescent-to-LED conversion questions
Just paid $14 a piece for 8’ T8 LED, which is cheaper than two 4’ LED’s and conversion kits, not even considering the extra labor required for the 4’ conversion.
Also, back in the days, all else being equal, 8' lamps had a slight efficiency advantage, because each lamp-end represented a certain amount of cathode loss. So, two ends per 8' instead of two ends per 4' gave a slight edge. In installations like big box stores with thousands of lamps, it also reduced installation and group re-lamp time especially when comparing 8' single pin vs 4' bi-pin since there's no need to twist or align the orientation.
F96T8/59W was a easy replacement that allowed the reuse of housing for F96T12/75W and F96T8/HO 86W was an easy replacement for 8' 110W.
As the age continues to accumulate, the number of legacy T12 fixtures going for a 2nd round of retrofit is rather few.
For a home garage, going with 4x4 instead of 2x8 is a no brainer. In practice, F32T8s don't really fail for 10+ years in residential use if it has a quality ballast. Bringing in just a handful of 8' lamps is a pain. Bringing home a replacement of a just a handful of 8' lamps is a pain. Storing 8' lamps is a pain.
The low production volume with declining popularity, the high breakage rate in warehouse/transit, difficulty in handling all contribute to higher prices for 8' lamps.
The single pin is a good thing for sure. The one thing I do like about 8 foot tubes. I wish all tubes were made that way & don't see why they wouldn't be. Much easier and better connection. Good tension keeps them snug against vibration.
