- Logan, Utah
They probably oughta be paying attention to something.:wink:
You are right on that.
Chris
Perhaps he wanted to see it drilled directly through the foundation wall? That would kind of make the statement make sense. Without the 90, it would have gone straight into the panel, right?
I think this young buck has hit the nail on the head with why you failed. I'd put money on it. Thats the only reason I can see.
Hi Don,
The LB into the structure may be okay, but using a PVC 90 Elbow instead of a full sweep may be too tight for the minimum bending radius of the conductor. The exterior Sch 80 into the building (even the lateral) wouldn't be a violation unless local code would require RMC or equal. Sure would like to know what the EI stated. rbj
