disconnect mounted to side of house for a/c unit, with
LP gas line with shut-off valve running right next to it 3"
can't find any location distance in code book?:-?
Note the restriction is created by the meter, not the piping. Closed piping systems, downstream of the gas meter, especially at the pressures common to residential installations are not an electrical area classification a problem.Section 5.7.2.3 Gas meters shall be located at least 3 ft (0.9 m) from sources of ignition.
