a/c disconnect
tbiertze
New User
Which of the following is not acceptable for an a/c disconnect? 50' from the condensing unit, inside the house, I know the answer is inside the house because it has to be within sight and readily accessible, but I can not find if 50' away is acceptable. Any help??
You need to look at Article 100:
In Sight From (Within Sight From, Within Sight). Where this Code specifies that one equipment shall be ?in sight from,? ?within sight from,? or ?within sight,? and so forth, of another equipment, the specified equipment is to be visible and not more than 15 m (50 ft) distant from the other.
fixed resistance question
Man, Im confused about one part of ohms law. How can it be in one text they show voltage and current being directly proportional. The voltage increases 25% and current will also increase 25% (for a given resistance)
Another book states that a rise in voltage will result in a lower current, which is the way Ive always been taught. what Am I missing here? Any help would be much appreciated...:confused:
