hurk27
- Portage, Indiana NEC: 2008
I went on a service call for a pharmacy a few cities over, because of a tripping lighting breaker and found these old panels still in use.
Lighting panel #1
The top left breaker was bad so there was two unused breakers one on each side of the panel, the one a few spaces below the bad one would not work but the one on the other side was ok? so I moved the circuit over to it, wasn't about to try to move the breakers around, I have never even worked on a panel like this, seen one a long time ago but I have no clue on how these breakers are attached?
Owner agreed with an upgrade, this panel will become a junction box, and a new 30 space QO panel will be located just below it, because there is no other room, it is fed from a 100 amp fused disconnect from a basement service 800 amp 4-wire delta service, this panel is fed from "A" and "C" phases.
Lighting panel #1
