- Massachusetts
..read all/most of your post on 'other' link, I'm guessing you don't like generac
Yeah, you have to read between the lines but you are correct :grin:
surprised to see Generac leading the way!!
Me too.
And if you're going to install a Generac, at least install a new Cutler Hammer one. At least you get CH controls with the Eaton/Generacs.
That's good info---seeing that I'm currently working on an estimate to do a generator install. It seem Kohler, and onans are a lot more expensive than the so-called cheapo Generac.I had a Kohler 30 KW water cooled propane w/watercooled turbocharged 1800RPM engine, Ran great and very quiet until the muffler rusted out at top of the enclosure filling the engine with water ( I did not have it on an exerciser, so I would manually crank it once a month or so) I pulled it to eventually rebuild it, but have a 12 KW Generac in its place right now, Much louder, but for the money, it's ok. I wouldn't back up a data center or any other critical load with a Generac though. I've installed Kohler and Onan residental units and they are much quieter, with the Kohler much higher in cost, and the Onan's slightly more than the Generacs.
