20' light poles in a water retention/park area. They installed them almost flush with grade and after a few years the pole base rusted and the poles fell over.
I used rod couplings and 1" x 36" threaded rod to extend the anchor bolts and built a little rebar cage around it. I rerouted the PVC to a masonry box and secured it thru the sonotube.
I used the "emt inside the pvc" trick to protect the wires from the sawsall.
I hope it worked. I will be setting the poles Friday.
