OK. I thought about it some more and the rod couplings are a good 4" up into the new concrete and I think that eliminates them as a weak point.
I will still epoxy the rebar next time but I'm not going to lose any sleep over this one.
Forgive the dumb question. How do you bend the rebar into the appropriate size circle?
Well crap. The bottom of my cages always sit in the soil. Do you think it's possible for the rebar to rust out all the way up into the concrete?
There is also the mason line as a saw to cut the pvc so it doesnt hurt the wires trick.20' light poles in a water retention/park area. They installed them almost flush with grade and after a few years the pole base rusted and the poles fell over.
I used rod couplings and 1" x 36" threaded rod to extend the anchor bolts and built a little rebar cage around it. I rerouted the PVC to a masonry box and secured it thru the sonotube.
I used the "emt inside the pvc" trick to protect the wires from the sawsall.
I hope it worked. I will be setting the poles Friday.
