a "roundhouse"ran to three gfci outlets=tripping
zappy
CA.
so me and my dad ran this and the gfci's tripped when you had a load on them.why?would you guy's agree that it's not a good idea to use a mwbc feeding gfci's?
iwire
Massachusetts
They are wired wrong or they are working and the load has a fault.
No, I will not agree, I do it quite often
A MWBC can supply GFCI receptacles.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
If you are feeding receptacles with a MWBC and the GFCI Breaker are 2 single poles then this will not work. You would need a DP GFCI breaker.
stickboy1375
Litchfield, CT
So why dont you explain how you wired them and maybe we can help you with your problem...
zappy
CA.
12-4 to the first gfci outlet,12-3 to the next,12-2 last
is there a better way?thanks
mdshunk
Right here.
Did you pigtail to each receptacle? If you pigtailed, your arrangement will work fine. If you have anything on the load side of those GFCI's, you caused your own problem.
infinity
New Jersey
Journeyman Electrician
stickboy1375 said:
Why the 12-4?
Three circuits. This will work fine with GFCI receptacles if wired correctly. It's no different than the 3 phase, 4 wire feed to the panel.
LarryFine
Henrico County, VA
stickboy1375 said:
The last time I saw a "roundhouse" was with Patrick Swayze in the movie Road House... :grin:
Funny back at ya! That was on TV this morning. :)
And, no, I'd never give a sarcastic remark. Not me.
