gar
- Ann Arbor, Michigan
- EE
161031-1426 EDT
junkhound:
With the following actual circuit the experimental results are shown in the actual oscilloscope plot.
The circuit:
Tektronix CFG250 function generator.
Rigol DS2072A scope.
Mid 1970s Tektronix scope probe, 10X.
Series combination from common to voltage source (sig gen output) ---
-- 82 ohm carbon comp for current measurement.
-- 1.0 ufd Sprague 730P capacitor.
-- 10 k ohm carbon comp for current limiting for charging capacitor.
-- The nominal time constant is 0.010082 * 1.0 seconds.
The plotted capacitor voltage includes the 82 ohm voltage drop (1% error in voltage, but not waveform).
The voltage source rise time is around less than 50 nS. Scope waveform of the signal generator includes the signal generator, scope probe, and scope combination. No apparent oscillation with or without the series circuit being tested. Source impedance is speced at 50 ohms.
Plot:
Blue is voltage across both capacitor and 82 ohm resistance. Essentially the capacitor voltage drop.
Red is the 82 ohm voltage (capacitor current).
Note that 63% of 6 division is 3.78 divisions, and the plot is close to that at 10 milliseconds. When the scope time base is expanded it appears that 63% is at about 9.6 to 9.8 milliseconds.
junkhound:
The circuit:
Plot:
