- New Jersey
- Journeyman Electrician
I've been given the task of installing an IG system for A/V receptacles in an existing Theater. Currently the A/V receptacles are grounded like a normal duplex device. All of the A/V receptacles are on the same phase of the 3 phase 208/120 volt panel as per the advice of the A/V consultant. The receptacles are existing and the new spec calls for all IG devices and the IG EGC's are to be two trade sizes larger than the phase conductors. Also the IG system is to terminate at the XO of a 75 KVA transformer which feeding an A/V distribution panel. Can someone please explain this design? Why does the EGC need to be two sizes larger than the phase conductors? What's so different about A/V equipment that this should even matter?
