I have a new situation to me. Currently there is a meter can on the outside of the garage wal and a main breaker panel on the inside, they are connected with a metal nipple. A #4 wire runs from a lug on the neutral bar in the mater can to a bonding bushing in the meter can, through the nipple to a bonding bushing on the panel side, then up to the ground bar.
I am going to be abandoning that nipple because I will be coming out of the side of the meter can to an ATS, and then run from the ATS into the garage and into the panel.
The question is this: What is the best way to abandone this nipple? Leave it exactly the way it is? Removing the bonding conductor from the lugs and bushings and just leave the pipe? Pull everything off and remove the pipe, then insert KO seals from inside of the meter can and panel (is that compliant)?
