Deltaforce
- India
- Electrical Engineer
Utility mv capacitors switching than lv capacitors switching likely voltage transientsAre the other customers fed from the same utility pole as yours, or are they fed from a separate pole? If there's a separate pole, then I suggest it also be checked for the presence of power factor correction capacitors.
May also check neighbors same issue
As utility switch mv capacitors same time
