after read some article in here, i am confused about bonding. If i have a 3 seperated building, two are production building, one is utility building including substation. for individual building we use Ufer grounding system, in utility building we add some grounding rod connecting to Ufer system as addundem to achieve proper grounding impedance, my question is when we run PE wire into the other two buildings, do i need bonding it to each Ufer system respectly? all equipment and metallic parts in these builds would bonding to PE bar or Ufer system in each building? Thanks!
