solo618
- Orange County, N.Y.
This is a permanent pool , not storable . My question is about the bonding wire that goes around the pool . I have seen in some posts that it has to be 18 - 24 in. from the inside wall of the pool, but is that for in ground only or above ground also ? Also do we only have to attach to the pool at four evenly spaced locations ? In the past I would just attach around the pool at the base . Thank you .
