Ok, you guys answered my question about the continuous load factor on the heater for this pool, but i am confused again about a few other question I have regarding this if someone can help.
1) After reading the nameplate it says (38a circuit ampacity), (Min. fuse 40a) and (Max fuse 60a). After my calculations it seems a 50a fuse would be fine. Is this ok?
2)The reason I'm asking, is because in class, the instructor told us when it comes to A/C condenser equipment, you should always fuse it at the max because the continuous load factors are already taken into consideration just for A/C condensor equipment. Is this correct? If not, how should condenser equipment be handled?
3)According to the code, do you need a disconnect switch for an above ground pool or is just a GFCI protected circuit fine?
4)Accoring to the code, should above ground pools require these circuits be ran in PVC (ENT)?
