Stevenfyeager
- United States, Indiana
- electrical contractor
A customer installed an above ground pool (approx 50 inches water depth) with pump with about a 24" twist lock cord. The pump is installed close to the pool beside a retaining wall and not where I can install an outlet 6' away with such a short cord. Can I replace the cord with a longer one or can I cut it and j box it and extend it to get 6' away from the pool? Is this considered a 'permanent pool' with this depth ? 680.2 Definitions. If so, is pool required to be bonded ? Thank you.
