I have an above ground pool wiring job and have two points of confusion. The pool is 28' diameter and more than 42" deep, so it is not a "storable" pool. The shell is metal as well as the top and bottom tracks and the support struts around the perimeter. The owner wants the pump and heater installed close to his house and then wants to run water feed and return PVC lines from the filter/heater to the pool. The distance from the filter and heater to the pool wall is 20' minimum. This is my first install where the filter and heater weren't out near the pool. Question one: with the filter/heater so far away, am I missing anything special that would have to be done? I assume I still need the convenience receptacle within 20' of the pool even though the filter receptacle is further away than this. I also assume I still need to bond the filter/heater to the pool wall. Am I missing anything? Second issue: the pool installer left the plastic covers off the bottom of the support struts around the perimeter of the pool. He told the owner that those couldn't go on until the "electrical was complete". This has to be a bonding issue, but doesn't 680 say running one 8 to the wall of the pool is what is required? Does the 8 need to run around the perimeter of the pool and hit every strut? The components are all bolted together and should be bonded through the connection hardware. Am I missing something here? I really appreciate any feedback on my questions. This site is a really great resource.
