Above ground storeable pool, factory cord and plug
Capital
morris plains nj
Above ground storeable pool, factory cord and plug supplying a filter motor, 15amp, 120v, 6ft. Do i need the change the cord to a 3ft #12 to comply? It will void the Warranty
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
As long as it is not deeper than 42" than it is storable. Of course the non metallic polymeric walls or inflatable walls can be any dimension and it would be considered storable
Storable Swimming, Wading, or Immersion Pools; or Storable/
Portable Spas and Hot Tubs. Swimming, wading, or immersion
pools that are intended to be stored when not in use,
constructed on or above the ground and are capable of holding
water to a maximum depth of 1.0 m (42 in.), or a pool, spa,
or hot tub constructed on or above the ground, with nonmetallic,
molded polymeric walls or inflatable fabric walls regardless
of dimension.
