Article 90.1
They work great in low-voltage landscape lighting, too.
Hmm... Never thought of that, good idea!
Of course. Speaking of weddings, we did our reception there by the pool. With the dolphins in attendance.
They make 4watt 8watt 14watt 21watt lamps you have to see what lamps you're ballast is rated for! Ive seen the tombstones melt from mismatched lamp and ballast
if the ballast will not do a lower wattage lamp lower your K value to like a 3000k it will soften the whiteness
My thoughts exactly! You will want to ask for "Neutral Density Gells" The photo/video world measures there lighting in stops, and therefore, you will order a 1/4, 1/2 full, 2 stop, etc. gel. A good grip company will have rolls available for you as well as sheets of varying sizes. There are two types of gells, the type that can be used with "hot" lights, and standard gells. The ND gells should not alter the color temperature of the lamp in theory, although, it is hard to believe when you are looking at the grey material. Hey why not get some 1/2 CTO gells and warm the lighting up a bit? (just kidding). The packing tape is going to be the least expensive option IMHO.
The dimming sleeve sounds like a great idea. I will have to try and keep those in my memory bank.I received and installed two t5 "Dimming Sleeves" last week and they worked great and at $12 a piece they were much cheaper than buying a dimmable ballast and dimmer. Thanks for all the help, especially Boltneck for the idea.
Last year I installed 2 (End to end) 4' t5's above the cabinets in my parent's kitchen. I did this to compliment the t5's I put under the cabinets (8" and 14" I believe) and the rest of the recessed lighting. Anyway, the four footers throw a little too much light, I then considered t4's but I see that the lumens are the same as the t5's. Now I'm unsure as to what to do, I need less light output and I don't want to use cheesy rope lights, any suggestions?
Ever seen my homemade GOBO light? (MR-16 lamp holder, in a 4S box, a housing of scraps from TAP plastics, an old telephoto lens, and various MR-16 color filters with letraset lettering)Cheap way to convert them to holiday lighting.
Red & blue for Memorial Day and July 4th. Red and pink for Valentines' Day....... Green for St. Patty's.......Pastel colors for Easter....... Orange and dark purple for Halloween....... Orange, brown & hellow for Turkey Day......... Red n green for Christmas........... Blue for my birthday..........
