rafeequepk
Zog,zog said:To charge a MV cable of any signifigant length with a 60hZ AC Hipot you need a huge power suply, the Xc of the cable @60Hz is very low, thats why VLF testing is done.
Xc= 1/(2(pi)fC)
The lower the frequency, the higher Xc (capacitive reactance).
The higher Xc (or resistance across the power supply output), the lower the current/power needed to apply a desired voltage.
60Hz Example:
At 60 Hz. a 1 μF cable has an Xc of 2.65 kOhms
At 22 kV, it requires 8.3 amps of current to test
Total power supply rating must be 183 kVA
0.1 Hz VLF Example:
At 0.1 Hz, the Xc is 1.59 megohms
At 22 kV, the current needed is 14 mA
Total supply power needed is 0.304 kVA
At 0.1 Hz, it takes 600 times less power to test a cable, or any other high capacitance load, than at 60 Hz. At 0.01 Hz, 6000 times higher capacitive loads can be tested than at 60 Hz.
It was really a worth explanation from u for the question why we usually we prefer DC hipot on New MV cables than AC Hopt. Thank you very much. I know that DC Hipot is more destructive than AC hipot. But what kind of destruction it can make on bus bars and CBs?
