gar
- Ann Arbor, Michigan
- EE
210529-1416 EDT
Broadly speaking I would say there are basically three classes of magnetic electric motors. These are DC brushed motors, AC synchronous, and AC induction. I do not consider a so called DC brushless motor as a DC motor, rather it is an AC synchronous motor with some sort of control to convert DC into AC. Also a stepping motor is really an AC synchronous motor.
What are called "DC brushless motors" should be called "DC brushless motor systems". The motor itself is not a DC motor.
DC brushed motors are based on a fixed magnetic field, and an integral synchronous mechanical switch (brush and commutator) to control what wire gets current to interact with the fixed magnetic field.
An AC synchronous motor has a steady magnetic field that interacts with a steady rotating magnetic field, or a pulsed magnetic field.
An AC induction motor has no steady magnetic field, but rather two oscillating or rotating magnetic fields interacting with each other with one field being generated by magnetic induction from the other. Slip of rotor vs stator determines the frequency of the second current.
Keep in mind that a North field attracts a South field and vice-versa.
See ---
en.wikipedia.org
See ---
Brushless DC electric motor - Wikipedia
en.wikipedia.org
