EEC said:
The AC voltage for coolant heater is not allowed in the same conduit with generator control wiring (according to generator supplier). Supplier says EC can intstall AV wiring in same conduit as the feed from generator. As long as there is room, does anyone see any code problem?
I have done it both ways.
But if I had the manufacture telling me separate it would be separate.
Many times we go with a raceway for the feeder, a raceway for block / battery heaters and another raceway for the controls.
It's a CYA world.
Another possible issue is lately annunciators if used are connected to the gen set with a LAN via a 2 wire twisted shielded cable.
You can not run the LAN wiring in a conduit with power conductors.
