I am doing conformance testing for IEC-61010. It is my understanding that Hi-Pot tests can be performed by either AC or DC voltage. Here is the wording of 61010:
"Solid insulation of MAINS CIRCUITS shall withstand the electric and mechanical stresses that may occur in NORMAL USE in al RATED environmental conditions during the intended life of the equipment.
Conformity is checked by inspection, and by the a.c test of 6.8.3.1 with a duration of 1 min, or for MAINS CIRCUITS stressed only by d.c, the 1 min d.c test of 6.8.3.2 using applicable voltages from table 5...."
My question is about "or for MAINS CIRCUITS stressed only by d.c" Would this mean only DC circuits, or does it mean that if you are doing the DC hi-pot test, then the MAINS circuit is stressed only by d.c...
What does "MAINS CIRCUITS stressed only by d.c" mean?
For the AC test, I need a meter capable of 500VA. Most meters I can find have AC ratings of 200VA. The 500VA meters are 5 times more expensive. This is why I would prefer to do the DC test.
