I have some CO detectors to install in a parking garage.
They can run on 24VAC or 24VDC.
I need to connect the contacts to an interposing relay for fan control.
The run will be about 300' to the last detector in #16 multiconductor cable connecting multiple detectors..
One power supply at the motor starters.
I want to make sure that the relay will pull in and the sensor has enough power given the length.
Would you use AC or DC for the power supply?
