AC quick disconnect wiring
dlenington
New member
Sanger, TX, USA
My AC quick disconnect box is wired from main with 10/3. The neutral wire is connected to the ground lug. I am installing a new AC whip. Do I need to disconnect the neutral and cap off since 10/2 is essentially what was needed? I am assuming I also need to remove the other end from the neutral bar at the main and cap off...or is it ok as is and connect the whip's ground wire to the same side of ground lug as source's ground wire?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
