AC to DC Isolation Junction Box
Please accept my apologies for the simplicity of this question. I've used this forum in the past for research and found it a wonderful source of helpful knowledge.
I was checking for what was code for an AC-to-DC power supply, to wire low voltage LED (24V, 60W < 96W).
I see this item ( http://www.goodmart.com/products/diode-led-lo-pro-junction-box-di-0980.htm ) and
this NEC reference:
http://ecmweb.com/content/code-rules-low-voltage-lighting
http://www.q-tran.com/sites/default/files/NEC article 411.pdf
However most of the supplies I have have screw terminals, so I can't exactly isolate them in another compartment- and adding a set of pigtails would seem silly.
I also have come up pretty much blank trying to find similar boxes- I saw one power supply stuffed inside a 2 gang metal junction box which (would seem not to) provide isolating the inputs.
What am I missing?
Thank you in advance-
JFletcher
Welcome to the forum. Do you have a link to the power supply you use? Some of those screw terminal types are made to be part of final unit inside an enclosure; they are not stand alone pieces.
Thank you-
The 3 supplies I have (I, sadly, enjoy buying cheap supplies at time and testing them on a scope for noise, etc) are-
http://www.meanwell.com/webapp/product/search.aspx?prod=LRS-50
http://www.trcelectronics.com/View/Mean-Well/PLC-60-24.shtml
And a very inexpensive unit that (actually) has covered terminals with decently rated plastic.
I appreciate the response and apologize for the delay- I've been on extensive travel for work.
Smart $
Esteemed Member
Have you read section 725.136. It is not a matter of being AC or DC, but rather circuit classifications.
Indeed- in fact, it was one of the explanations that circled me back to this site-
https://cdn.shopify.com/s/files/1/0221/7316/files/NEC_725.136_-_Help_for_a_Manufacturer_2.pdf?7534444860945924288
I was have just been hung up on the 'isolation' of the high voltage and low voltage. No box (unless I buy a 4x and gang them together), or buy a 'project box', and attach the power supply in there, seems to have the necessary OTS clearances.
I have seen installs in various hotels (shiver) where the open frame PSU is just sitting on the back of the bar/under the table. Just trying to do it right.
Can I necro this thread? Has there been any new products in the industry that anyone is aware of that satisfy the combination of isolation and separation for AC-to-DC electrical connections?
