fraymond
- Huntsville, Alabama
Recently someone brought up an idea to purchase visual devices to indicate removal of voltage after the enclosures disconnect is turned off.
They also indicated using acrylic/plexi-glass to cover the line side of the breaker to protect from shock rather than removing the voltage source feeding the enclosure. The load side would have small holes drilled to insert meter leads. PPE would not be required after determining the voltage source is absence
I am under the opinion visual devices are not mentioned in OSHA/NFPA-70E for determining absence of voltage nor I have seen anything on leaving voltage on the circuit breaker even if it is covered.
Am I missing something with my opinion(s)? Thanks
