Accessible or not
Then you need to challenge the electrical inspector with the facts. Code references. Why be afraid of an inspector?
No, the best thing is to cut them out of the equation entirely. I don't need some failed electrician turned inspector making up rules on the spot to tell me how I should be doing my job.
Sounds like your area has some lousy inspectors. :thumbsdown:
Well, I guess I'm in the minority but I don't follow the reasoning of this being accessible. Later part of the definition says "not permanently closed in by the structure or finish of the building". You call for a final, the project is finished, as in all the lights are installed. Only accessible if someone knows it's there, but one poster said he would leave a note. I would say write on the trim in black magic marker, (j-box above).
That would be me. I am a firm believer of not screwing the next man, especially since I am often the next man.
I've done enough trim replacements to know to razor-knife the things, or that overpaint WILL damage the drywall when you pull it out. That paint will tear the paper every single time.
The finish of the building would be the Sheetrock, paneling etc it is not the light trim.
If you feel that is not enough you will need to put in a code proposal change asking that the CMP make our job easy. :D
The same thing happens on receptacle and switch covers.
Great point!!
So i guess we all fail the final inspection EVERY TIME. because the wires are covered by the "Building Finish" called cover plate.:D:D
Well I guess I'll eat the humble pie here since I can't find anything else about this, maybe acceptable industry practices, but I don't know if it's a good battle to be fought with the ahj. I have actually done similar myself on occasion over the years,(I can finally sleep now), but always a last ditch effort. (the op did say it was a remodel, maybe there were other options). I saw an old post that was similar to this, someone mentioned "inner turmoil" about a box behind the upper cabinets? :happyno: Maybe UnderBudget will let us know how it turns out. And now I think I'll watch some football!
