HomeInspectorKenton
- Boulder, Colorado
In a situation in which conductors would normally be run between 1st and 2nd floors inside vertical conduit, when a log wall might settle up ro 7 inches over time due to log shrinkage, how can that be accommodated? With plumbing drain and vent pipes, slip joints can be used, but not with conduit because of the potential loss of conductivity. For water supply pipes they use a coil of copper tubing that flexes to accommodate movement. Can a coil of armored cable be used for this purpose? Is there another alternative?
