zbang
- Roughly 5346 miles from Earls Court
That seems a bit fishy as threads are usually cut after the pipe is coated, like in the field.because the galvanizing on the threads could impede the gas seal
My understanding is that when natural gas systems carry gas with a significant sulfur content, the zinc coating can react to make ZnS, which can form fine particles carried in the gas that can plug orifices in burners. But most (all?) modern natural gas systems now carry low sulfur gas, so the concern is reduced and it's fine to use galvanized for natural gas.This was probably 20 years ago, but I remember my Plumber friend (Licensed Journeyman Plumber) said that galvanized pipe could not be used for gas because the galvanizing on the threads could impede the gas seal, even with dope.
That is all false.I did a bit of online research. It appears that galvanized is NOT recommended for pluming due to poor corrosion resistance and the possibility of the galvanizing flaking off and clogging lines. Strangely, Black Iron is considered more corrosion resistant due to the coating and the low carbon composition. Learn something new everyday.
Mark
Don't know where he is located but most national codes allow galvanized for gas and some states like NJ are near the ocean and require it. I live in MA. and am a licensed gas fitter. MA does not (and never has) allow galvanized pipe use on gasThis was probably 20 years ago, but I remember my Plumber friend (Licensed Journeyman Plumber) said that galvanized pipe could not be used for gas because the galvanizing on the threads could impede the gas seal, even with dope. He said you had to use black iron, as its threads are bare steel. I have no opinion on the validity of this, but this thread had me curious.
Mark
Wives tale.Galvanized piping would flake causing pilots to plug. Maybe even messing with solenoid operation.
Could be. I know we weren't supposed to use it with propane and worked with enough plumbers at the time to know it wasn't allowed by them.Wives tale.
I've used it with propane and NG plenty and also disassembled it after having been in service for the greater fraction of a century. There is no deterioration of the inside, zero. There is no code anybody has been able to show that disallows it.Could be. I know we weren't supposed to use it with propane and worked with enough plumbers at the time to know it wasn't allowed by them.
The fittings are mostly iron, I believe.The black pipe and fittings installed for gas is not black iron. It the same steel pipe as the galvanized but has a paint coating instead of galvanized.
Standard gas fittings are something called malleable iron. It is cast to make them. Only high pressure fittings are forged. I don't know what malleable iron actually is. I don't think it is used in any other common application any more.The pipe is mostly common steel and most fittings are forged. There are some cast versions, cant remember it all but both have bit higher carbon I believe which gives them strength but sacrifices ductility. They will weld but not reliable without special precautions.
Core Specifications for P&S Steel
Regardless of length, the following core quality standards applied (and still apply):
- Minimum Thickness: Must be at least 1/4 inch thick.
- Composition: Must be clean, "alloy-free" steel. Acceptable items include steel plates, structural shapes (beams, channels, angles), crop ends, and shearings.
- Chemical Limits: Phosphorus or sulfur content must not exceed 0.05%.
- Excluded Items: Generally excludes rebar, cast iron, pipe (unless split), and anything with non-metallic attachments or excessive rust.
Gas stations that I have observed are all galvanized pipes running everywhere.I've always heard that galvanized shouldn't be used for diesel or gasoline. I never used it for either. Black iron is cheaper anyway.
I originally heard that from G&R Cat (Our local cat dealer) back in the 80's. If I remember right they told me about installations where galvanized was used to run from the bulk tank to the day tank and it messed up the float in the day tank for the transfer pump.Gas stations that I have observed are all galvanized pipes running everywhere.
