My thoughts too. And that's probably the answer expected.I inferred that their use of the word "continuous" meant a string of one load after the other - which would be a series circuit.
Body having jurisdiction! My go to when I don't know. I did think (D) or (B) .I had to pause on this one.
None of the choices seemed correct to me.
Which answer would you choose?
A circuit in which all the loads are connected together by one continuous source of electrical current is called a ____________ circuit.
A-AC
B-SERIES
C-PARALLEL
D-DC
JAP>
I went with series because of what they drilled into our heads during my apprenticeship.
"Current is the reference in a series circuit"
"Voltage is the reference in a parallel circuit"
Meaning in a series circuit, the current through each load, no matter what the impedance, will be the same.
Actually, you are trying to figure out what the person who wrote the question thinks is the right answer. That's the only way you get credit for it.And also remember you are trying to figure out the correct answer, which is not always the best or most accurate answer. It may not even be the right answer.
parallel
that is the only answer where there is just one circuit
a = i , right?Like they are spelled.
Series = e+e and i is the same.
Parallel = a+a and e is the same.
He's saying that the word "series" has two "e"s and one "i" in it, so that means that voltage (e) adds, while the current (i) is constant. Likewise, "parallel" contains two "a"s and one "e", so current (a this time) adds while the voltage (e again) remains the same. A remember tool.I have no idea what this means.Like they are spelled.
AC and DC are not descriptions of circuits, they are descriptions of sources.
Only parallel and series describe circuits.
As I said before, a series circuit has the current for the reference.
The above is not in defense of a poorly worded question, it is my reasoning for my answer.
