Adding a sub panel... parallel to the main load center. Is this right?
JoeGam90
New User
oregon
engineer
I have a home with a very typical setup for Oregon, a meter feeding a 200A panel. The meter is on the wall of the house. The main load center feeding the home is full, and in a pretty bad spot to try to replace it with a larger panel (would require removal of cabinetry, etc). What I want to know is if I can install a Feed-Through-Lug load center between the meter and my current home panel. I believe I will have to remove the neutral bond at the home panel since that will become a sub panel. I then will need a ground rod and bonded neutral at the new primary panel (the one I'm adding with the pass through lugs). See the attached drawing (nope, this forum won't let me upload images), it will likely make way more sense.
I have added replies about images, they are all being held for moderator approval. Good luck and sorry.
I am closing this thread in accordance with forum rules. This forum is intended for use by electricians and electrical contractors, inspectors, engineers, and vendors with their job-related duties. We are not allowed to provide how-to advice to persons who are not employed in this industry, or persons who do not perform electrical installation or maintenance as part of their jobs. Engineers are welcome to participate, but only if their questions do not involve attempts to perform their own electrical installation, troubleshooting, or maintenance work.
If I have misread the situation, if for example you have an electrical contractor on board to perform the installation work, then send me a PM to explain the circumstances.
