Adding Grounds...
How long are the runs and how many bends? Unless you're going to pull out the 750's your only hope is to get a duct rodder type fish tape through the pipe and then pull in a rope.
Did you just forget about grounding?
I believe this is related to the other thread where they're inserting a service rated ATS in the existing run making the condutors a feeder and not service conductors.
Is the question whether to try just adding the EGC vs pulling the wires out and adding it?
It depends on many things, but I'd want to try adding it first.
