Yes its a mustromeo said:Any outlets added to existing bedrooms shall be AFCI protected,am I correct??
flick said:"Of course, if you add AFCI protection to the circuit that powers that one new receptacle, there's a good chance that most, if not all, of the other outlets in the bedroom will get AFCI protection at the same time."
I often add AFCI receptacles in homes with K&T where it is impossible to AFCI protect the existing receptacles because of the way the K&T was wired.
John
Jim W in Tampa said:Any problem with triping from the old wiring ?
Jim W in Tampa said:Yes its a must
It does sound stupid,5 others without but the one new one needs protected.
iwire said:You and I sure think differently.:grin:
So when you add a new circuit to a home with K&T is it also stupid to include an EGC 'cause the other circuits don't have an EGC'?
We seldom agree but when we do i put a mark on my wall.We are up to 4 LOLiwire said:As I said, we just see things 180 degrees apart.:grin:
shortcircuit2 said:Romeo...
I have read some comments that interpret your question differently.
If outlets are being added to an existing branch circuit that feeds this bedroom...then I would say AFCI protection is not required according to 210.12 of the 2005 code.
But, if a new branch circuit is in installed to feed outlets in an existing bedroom...then I would say AFCI protection is required.
shortcircuit2
shortcircuit2 said:If outlets are being added to an existing branch circuit that feeds this bedroom...then I would say AFCI protection is not required according to 210.12 of the 2005 code.
shortcircuit2 said:Seems to be open to interpretation to the AHJ...
shortcircuit2
