tx2step
- North Texas, DFW area
Older house, with an old Federal Pacific stab-lock panel in a bedroom closet. They need to install interconnected (and 120V powered with battery backup) smoke alarms to 3 bedrooms and the hall (4 total) to meet occupancy codes. The plan is to power the smoke alarms off an existing 15A lighting circuit. The wiring will be #14/3 W/G NM.
Have any of you guys done something like this before?
What is the best/easiest way to meet 2014 NEC 210.12(D)?
I've never seen a combination type AFCI circuit breaker for an old Federal Pacific panel - are there any out there?
I'm thinking - cut in an outlet box just below the existing panel, install an outlet branch-circuit (OBC) AFCI receptacle in it, and feed the lighting circuit down through that and back up into the panel to provide AFCI protection for the entire circuit.
Another approach would be to power it off an existing receptacle circuit and change out the first receptacle in the circuit to an OBC AFCI receptacle -- but that may take longer to do, since I'll have to find the first receptacle on the circuit, and see if there is anything else on the circuit that might cause problems. And the location may be behind furniture, so resetting could be a pain.
Anyone have a better idea or method?
What's your experience with OBC AFCI receptacles? I haven't installed one yet.
They are also available as OBC AFCI/GFCI combination receptacles -- has anyone use one of those yet? I'll probably need to use them for replacements in kitchens, laundry and bathrooms?
Thanks for the help
Thanks for the help
