Advice: Sizing conductors for long 200amp service run
keaton85
New User
Maine
mechanical engineer
This will probably be a quick one for you guys.
My wife and I are building a house and about to order the cable for the service run underground. Yet I'm not 100% on what is a safe bet.
200amp service at approximately 265ft from meter to load center. I was going to run 250 for L1 and L2 with 3/0 neutral and 3/0 ground, yet I'm pushing a little to much voltage drop even though we likely won't hit 200amp very often, if ever. I would go with 350 for the hots but I foolishly installed 2" conduit in the slab! Although i have 2.5" run from outside the house to the pole.
I can legally run without a ground before NEC 2020 code takes effect since my load center is within 3ft of the point of entry thus not required to have a disconnect. Which im trying not to take that risk, since i would like to have a disconnect and breaker on the mains.
Any advice on sizing the conductors? I'm unsure on what's required for the neutral and ground sizing.
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain. Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
