We are installing several security cameras on existing wood poles on a project we are doing. The security cameras will be powered off a 120VAC, 20Amp circuit breaker fed from an existing building with aerial conductors.
The question is: Would an equipment grounding conductor be required in the aerial power run between the building and the pole? Or, should a separate Grounding Electrode be installed at the pole location only, or both?
