marmathsen
- Seattle, Washington ...ish
- Electrical Contractor
I'm looking for some advice on steps to be taken and tools to use when doing advanced troubleshooting of tripping AFCI and GFCI circuit breakers.
I can fairly easily troubleshoot and resolve issues where the circuit is constantly tripping or consistently tripping under a specific scenario. If there is a low impedance short between any of the conductors, that is fairly straightforward to track down. Usually by starting in the boxes where multiple circuits are likely to be to look for combined neutrals from more than one circuit. Or split the circuit in half then test the breaker, then split it again and test, etc.
Where I run in to issues is where the tripping breaker is more intermittent and unpredictable. For instance I have project where a kitchen counter circuit was tripping but of course never while we were there. We replaced a Square D Homeline 1 pole 20A Dual Function breaker under the premise that the breaker might be bad. Well of course now that it's a month later, the breaker has started to occasionally trip. But only occasionally.
I have done a lot of digging try to find a good resource for doing more advanced troubleshooting. I have seen a lot of people recommending to "Megger" the circuit. I assume they mean to do an insulation test. This is not a tool that I am familiar with and have never used. It seems like this could be used to find high impedance parallel arcing, but does it work for series arcing? I'm guessing no...but maybe I'm wrong. I even saw one installer mention that they test every circuit first before landing it on the breakers, then if stuff starts tripping after the drywall and other trades come in, the electrician can comfortably say "not our fault, we tested it". Does anyone else do this? Am I totally off base on what a Megger is?
I also have come to realize that BR dual function breakers have a whole suite of error codes that can help to troubleshoot circuits. 6 separate codes to be exact: Series Arcing, Parallel Arcing, Overload, Overvoltage, Ground Fault/Grounded Neutral, Self Test Failure. This seems like a potential diagnostic tool that one could use in a compatible panel on a temporary basis to diagnose, and it seems superior to the limited diagnostics Square D builds in (Square is is our standard). Does anyone out there use the BR breakers as a useful tool in other branded panels?
What techniques and tools do others use to troubleshoot and/or verify your circuits?
Insulation tester?
BR DF breaker?
Thermal Camera?
Sacrificial offering to the electrical gods?
Are there tools that can test for potential series arcing, like a loose connection?
Are there tools that can help locate a fault? It looks like Megger has some but I'm gonna guess that they are $$$$$$$$ since they appear to be intended for industrial and utility uses.
Hopefully you all have some good advice headed my way. I look forward to hearing what you have to say.
Rob
Insulation tester?
BR DF breaker?
Thermal Camera?
Rob
