A
a.wayne3@verizon.net
Guest
The other day while doing a hot check on a home
I ran into the following situation.while turning on all breakers the trim crew had placed 2 afci breakers on opposite sides of a panel on the same buss bar.I tured the left breaker on and then the right ,Both tripped out.I figured at first that these circuits had been double fed since when I turned the 2nd breaker on it tripped the other one.As it turned out theses were not double fed
the trim crew had placed ground wire of a receptacle on the hot side casing the circuit to trip.Ok that make sence but why did it trip the other breaker,By the way these were homeline sq d
panels.any thoughts...........
