olly
- Berthoud, Colorado
- Master Electrician
I am wiring a very small building that will consist of a small conference rm, small office, a small general use public info center and a restroom. Is AFCI required here?
Take a look at 210.12.
AFCI NO. ADA requirements. Yes. The only reason I mention it, it's easy to forget going to commercial.
What are ADA requirements, by that I mean are your regular outlet height of 18" off the floor OK?
I didn't see conference rm or office's and I believe 210.12 is for dwellings or dormitories only. I assume the answer is NO, AFCI's are not required in this application. Sorry for the lack of experience question. That is why I ask, lack of experience.
Is that 18" to top, bottom or center? On rough-in I normally go 20" to top just to make sure. That would put the bottom of the box at 16" and would allow for hardwood flooring. That's a little over kill according to some folks but it's better to be safe than sorry. Make sure the switch boxes don't get above 48".to top.
the reach range is 15 in to 48 in so you have to fall between those limits
So one could put general lighting switches 18" off the floor and it passes
Bet you don't get asked to put them there in most NBA player's houses![]()
