franticfrank
Has anyone run into a problem with moisture condensation inside an AFCI breaker?
I have had a few service calls for AFCI breakers tripping. When I removed the breaker it looked OK. I then noticed moisture inside the breaker , struck it against my hand and a whole lot of water came out.
This has happened a few times now on different jobs. I know that AFCI's create some heat, can this heat against the cool busbar be causing condensation? The standard breakers are bone dry.
The panels are located in basements with no noticeable moisture problems. If someone has run across this, a little advise would be greatly appreciated.
Thanks in advance
Thanks in advance
