Pierre C Belarge
- Westchester County, New York
AFCIs "SENSE" the signature of the arc. It can determine the difference between the good-arc as opposed to the bad-arc.
The lighting receptacle would become a new extention to the existing branch circuit.
- JWC
So what manufacturer makes a AFCI recptacle that I will replace the existing receptacle where I tap into to power the new extention of the Branch Circuit conductors for the new Light in the bedroom.
I feel it is opening a can of worms if a new AFCI breaker replaces an existing standard breaker. I don't know how good the existing wiring is. Then I get a call from homeowner with a problem on the old part of circuit that was upgraded. Then it could become my problem on my time.
I know we have to think about the bottom line (which is why I'm a little thankful I take check instead of signing the checks) but what about the fact that if the AFCI "is opening a can of worms" then there is obvious a problem?![]()
Good point,.. but the thing of the thing is ,. that it is very hard to explain this to the home owner when the outlet they wanted goes from about $125 to $800 ,. cause you had to spend all day chasing grounded to grounding faults and inadvertent shared neutrals ,.. or do you just leave those and start ripping up the joint so you can add a new circuit and or sub panel ??
You could always explain this before hand ,.. that ,..
"it could cost as much as a 800 dollars to add that ..(sound in ear) click "
The answer to this is EQUAL ENFORCEMENT.
If all code enforcers and electrical installers were/are on the same page, the issue of explaining to the customer what is needed to be installed would diminish quite a bit.
