Well were way off topic of course you dont need a AFCI on a furnace,
The RCD and GFPE will not detect an arc fault.
Hal like the term '
grounding' has little or nothing to do with the earth the term
'arc fault' is a abstruse poor choice of a term to classify a type of residential electrical fire common on single family dwellings (SFD) that a 15 and 20 amp 120V inverse time breaker does not prevent.
In the mid 1970's they set up the National Fire Incident Reporting System (NFIRS) to collect standardized fire data.
When Firefighters fill out paper work after a fire they use NFIRS codes like
'445 Arcing, shorted electrical equipment' the term
'arc fault'
is a wide paint brush not how most industrial guys use the term.
In the 90's SFD (and residential occupancy) fires were a focus of the United States Consumer Product Safety Commission (CPSC).
The facts are hard to ignore Single family dwellings (SFD) tend to have more NM cable than other types of construction, on average there are about 9 SFD's to about every other type of structure in a given area of the U.S.
Looking at surveys of the US like the American Housing Survey (AHS) SFD's are about a 9:1 ratio with all other structures, everything from duplexes to large high rises, commercial industrial etc.
Surveys of licensed electricians show the majority of their work is
not on SFD's. Surveys going back decades by magazines like EC&M show ECs get more of their total gross from commercial, industrial, utility and institutional (CII) work than from residential projects including multifamily.
So in the US we have a lot of structures that only a few electricians are working on, loaded with cheap appliances and cords.
In 1992, the United States Consumer Product Safety Commission (CPSC), engaged Underwriters Laboratories (UL) in a study to help evaluate products and technology that would help reduce these residential fires, other initiatives were also introduced like offering limited residential licenses to entice installers to get some education.
My point is these are not all 'arc faults' and arc fault is a misnomer.
TLDR yes I agree In my personal opinion little of this 'AFCI' craze has to to with a
'arc fault' but do we ignore a higher amount of electrical fires from a large stock of residential housing, with a cheap wiring method, installed by untrained persons and a trend of non-listed appliances , lighting, and extension cords and power strips?
I think another fix for that is to allow the use GFPE (or RCD breakers) .
Early generation AFCI's had a built in GFPE and that in my opinion is what was doing the effective protection.
If you look at the proposals at the time (1999) people like Sam Rosenbaum of Leviton had a competing product that was a leakage current detector basically a UL RCD Log #3356 , however some interests wanted to tip the tables in favor of a particular patented proprietary product when there were many products that can address the problem.
just my 2% Cheers
