 - Illinois
 - retired electrician
?????????????????????????????Non-renewal & cancellation is not currently my burden to challenge, but good luck with that.
There is only one kind of insurance that wont be revoked.?????????????????????????????
Nice work. Line side issues are also an amazing discovery.Turned out to be a neutral wire leaning up against a metal box
What makes you think it was a Line Side issue? The exterior light was most likely on the the AFCI that was tripping.Nice work. Line side issues are also an amazing discovery.
Maybe not this time, but something to consider for next time.What makes you think it was a Line Side issue? The exterior light was most likely on the the AFCI that was tripping.
We've certainly discussed it many times.I've seen line side issues cause a GFCI receptacle to trip before.
I've only read about walki talkies, or thunder storms tripping GFCI's.I've seen line side issues cause a GFCI receptacle to trip before.
Been like 10 years or more but I had a wall switch type occupancy sensor left over from a job and thought I'd put it on the bath light in my shop.I've only read about walki talkies, or thunder storms tripping GFCI's.
Never thought upstream electronic line noise could bother a GFCI?
Good to know.tripped a GFCI on back side of wall
Except it was not on the load side of the GFCI, and the light still operates when GFCI is tripped. I don't think I even have anything connected to the load terminals of this GFCI.If it had no neutral terminal, it probably sent enough current into the EGC to trip the GFCI.
